Re: Help with Cub Lo-Boy Fuel Problems??
Posted by Janicholson on May 26, 2009 at 16:24:47 from (66.173.50.161):
In Reply to: Help with Cub Lo-Boy Fuel Problems?? posted by IHMANKY on May 26, 2009 at 15:20:44:
Water in the gas can plug up systems and look like modern fuel. Did you add gas to it?
Using an inline filter with gravity feed flow rates is really necessary if you desire to use a filter. They are available at NAPA, and are larger. The filter not filling indicates the stoppage may be between there and the tank pickup tube at the sediment bowl. One issue is the intermittent nature of the stoppage. I would run it up the hill, and when it quits, I would then look for the blockage. JimN
