Re: 1946 Farmall A problems
Posted by Janicholson on May 26, 2009 at 16:56:22 from (66.173.50.161):
In Reply to: 1946 Farmall A problems posted by jamieei on May 26, 2009 at 16:28:11:
It might be stuck in reverse. If it continues to go backward when cranking it in neutral, do not start it. The shifter can be taken out, and the slots in the shift rails can be re-aligned. The tip of the lever gets worn, and allows it to slip out of a notch while still in gear. A new style starter drive is available to fix the issue you have. Clutch type is the new style.
This is the best place in the Universe for info and we are friendly. JimN
