Posted by Chuckle on May 28, 2009 at 07:18:53 from (71.253.69.246):
I bought a 340 gas about a year and a half ago. The engine was rebuilt before I bought it (less than 100 hrs) and it ran fine when I loaded it and unloaded it. I partially disassembled it to fix a few hydraulic leaks and to repaint it (mostly just sheet metal and the hydraulic pump). I finally put it back together and other than a new rotor distributor and plug wires everything was the same as when I took it apart. However, it won't start. I changed the points and condenser and the plugs, it is definitely getting spark. It seems like a fuel issue. The carb (a Zenith) was put on just before I bought it. I tried using starting fluid, I even pulled the plugs and put gas in the cylinders. It seems to sputter but won't fire up. I ran a compression test on it and cylinders 2,3 and 4 and they were all around 130 lbs, however number 1 was around 90 lbs. I wouldn't think this would cause a starting problem, but I could be wrong.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
