Posted by El Toro on May 28, 2009 at 09:48:17 from (205.188.116.73):
In Reply to: 340 won't start posted by Chuckle on May 28, 2009 at 07:18:53:
Are you sure you have the plug wires are in the correct firing order? Bring No1 piston to TDC on the compression stroke and note which way the rotor turns, its probably CW and both valves should be closed on that cylinder. Once you have No1 piston to TDC see if it's pointing at the No1 plug tower. That wire should be connected to the plug near the radiator. The other wires should be connected CW in this order on the cap. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
