Re: 140 hydraulic questions
Posted by Hugh MacKay on May 29, 2009 at 09:25:14 from (209.226.247.66):
In Reply to: 140 hydraulic questions posted by hoopnitram on May 29, 2009 at 04:52:31:
Hoop: Forget about Kirsch, I know what you talking about on rear hydraulics. You say the screen is clean. What is the condition of the hydraulic oil, clean or water saturated? Does the tractor have fast hitch with left side assist spring?
I some how have a feeling the two fron rockshaft are catching on one another. This may be why you have to lower the rear before front will lower. Does the hydraulic system have any external leaks? Does the hydraulic system loose oil, that you can't notice going?
I have a feeling the pump is not the best, but that doesn't explain having to lower one to get the other one to go down. Are you aware of the adjustment on the hydraulic levers.
Answer those questions, someone will figure it out.
