Re: 140 hydraulic questions
Posted by hoopnitram on May 29, 2009 at 14:17:20 from (64.85.221.190):
In Reply to: Re: 140 hydraulic questions posted by Hugh MacKay on May 29, 2009 at 09:25:14:
I didn"t mean to start any trouble, when I said rear lift I meant, rear rockshaft I guess..
The oil was old, no water, some sediment in the bottom of the housing, what I would think is normal..
No fast hitch, but it has the assist spring, I made a 3 point for it like I built for my super a..
The unit is wet around the head area, not what I would call excessive, no drips..
I will disconnect the links from the rock shafts to check for any binding etc..
Can you walk me thru the stop clip adj?
The front has the cultivator assembly that I have a couple cultivator feet with 2 grader blades bolted to it.
Thank you for your time,
Hoop
