CALLING BERNARD LE MECANO
Posted by MARK R on May 30, 2009 at 19:02:31 from (75.90.247.65):
HEY BERNARD,ON MY 485 WITH THE THE HICUP IN THE 3 PT LIFT,YOU SAID TO CHECK THE CONTROL LEVER AND THE RESPONSE TO LOWER.WELL,IT LOWERS WITH ANY MOVEMENT OF THE LEVER,EVEN A 1/4 OF INCH MAKES IT MOVE.YOU SAID THIS MEANS THE DROP VALVE IS TOO TIGHT AND CAUSES THE HICUP.OK,WHAT IS THE DROP VALVE,WHERE IS IT,AND HOW DO I ADJUST IT?IAPPRECIATE YOUR HELP,THANKS,MARK.
