Posted by CenTex Farmall on May 30, 2009 at 19:08:16 from (166.128.41.11):
In Reply to: H low oil pressure posted by CJ_1080 on May 30, 2009 at 16:29:40:
I'd say the same as JNicholson, use a 15w-40 "diesel" oil, such as Chevron Delo 400 or Shell Rotella. (If you read the label real close they're actually intended for mixed fleet use) They're made from premium base stock and have anti-wear additives in them that these flat tappet, shaft rocker engines just love!
Same on the oil pump end clearance. One time I had an M oil pump that had a lot of shaft wear right near the gear end causing. The gear was starting to eat into the pump housing. Had a new shaft made to avert a disaster.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
