H low oil pressure
Posted by CJ_1080 on May 30, 2009 at 16:29:40 from (166.223.208.94):
I just got done redoing the motor in my 1941 h. When I start it when the motor is cold I have about 35-40 psi oil pressure. After the tractor warms up it drops. At a lower idle I only have around 10 psi or so. This seems a little low. I use it for food plots and tractor pulling. Any advise is appreciated. I also use a 5w30 oil if that matters.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
