Re: H low oil pressure
Posted by Steven f/AZ on May 31, 2009 at 04:08:31 from (24.121.133.155):
In Reply to: H low oil pressure posted by CJ_1080 on May 30, 2009 at 16:29:40:
I run Mobil Delvac 5w-40 in my rebuilt H and it carries 70 psi all day long. When it is hot, the pressure will drop down to 50 psi at idle.
Spec for H's and M's and such is 75 psi.
I would start with the relief valve, then the oil pump. Heavy oil is a band-aid, I wouldn't be afraid to run 0w-20 in my H.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
