Re: A couple SH issues
Posted by Bob M on June 01, 2009 at 19:09:08 from (74.74.133.11):
In Reply to: A couple SH issues posted by Mr. Mayor on June 01, 2009 at 18:36:31:
You might be able to force a 1/8" pipe plug into the hole - preferably a brass plug if you can find one. Clean the hole then butter the plug lightly with JB Weld before screwing it in.
I wouldn't recommend using a cork - sooner or later it will loosen and pop out.
For your electrical issue try working through the troubleshooting chart below. It should help you ID the source of the problem.
I own a '53 SH myself - a fine tractor indeed!
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
