International 350 timing gear marks
Posted by Jeff in Cincinnati on June 02, 2009 at 10:41:42 from (63.250.143.9):
I am finally putting this C169 engine back together. The cam broke and I have the replacement cam already in. The timing gear is marked with a dot on one tooth and 2 dots on a tooth that is 180 degrees away. The crank gear has a single dot and the pump/distributor gear has a single dot. Which single dot do I line up with my cam gear single dot? I surely want to put this in correctly.
Also I need to reset my valve lash. Does anyone know what the cold valve lash settings would be on this engine?
Thanks in advance. This site is great
Jeff
