Re: International 350 timing gear marks
Posted by Bob M on June 02, 2009 at 11:16:55 from (151.190.254.108):
In Reply to: International 350 timing gear marks posted by GA Dave on June 02, 2009 at 10:41:42:
Jeff in Cincinnati said: (quoted from post at 13:41:42 06/02/09) Which single dot do I line up with my cam gear single dot? I surely want to put this in correctly.
Jeff - Line up the SINGLE dot on the cam gear to the mark on the crank gear, and the DOUBLE dot to the mark on the pump gear.
Tip: Make sure the distributor rotor points to the #1 plug tower on the cap before you mount the pump! If the rotor is pointing to #4 give the pump gear one complete turn so the rotor points to #1, then mount the pump to the engine.
