Re: 1066 Transmission Noise
Posted by Owen Aaland on June 03, 2009 at 17:45:59 from (65.165.246.186):
In Reply to: 1066 Transmission Noise posted by Lunatic Fringe on June 03, 2009 at 06:00:56:
If the noise started when the TA was replaced it is possible that you have gears that mesh together that do not the the correct tooth angle. Originally this series transmissions (starting with the 706/806) were made with gears with 20 degree pressure angle on the teeth. A change was made to 25 degree teeth to eliminate some of the noise. Running one of each will cause noise.
It is also possible that the MCV was installed with the thin gaskets when it need the thick ones. That will cause the hydraulic pump gears to be too tight.
