Posted by Hugh MacKay on June 04, 2009 at 02:16:13 from (216.208.58.98):
In Reply to: 686 Power and Tires posted by Stigmont on June 03, 2009 at 15:45:09:
Stigmont: I went from 15.5x38 to 16.9x38 on my 656 and 560, did it mainly to give better rear end clearence. At the time I also went from chloride filled 15.5x 38 to no chloride in the 16.9x38. Yes it did make a huge difference. With 15.5 on the 656 I never gave a thought to hooking up to 5x16 semi-mount plow. After the change to 16.9, all I ever plowed with was 656.
I don't think you want chloride in there, 16.9 and 18.4 hold a lot of chloride. It will rob the 686 of too much power. I noticed this in my change from 15.5 to 16.9, tractors were much more lively and resopnsive, didn't leave near as many wheel tracks in soft ground. I noticed the same going from single, chloride filled, 20.8x38, to dual, air only, 20.8x38 on 1066. I takes hard ground to take advantage of all that added weight.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
