Re: Farmall 656 doesn't start- could it be a stuck clutch?
Posted by Janicholson on June 04, 2009 at 10:47:13 from (66.173.50.47):
In Reply to: Farmall 656 doesn't start- could it be a stuck clutch? posted by JMS1234 on June 04, 2009 at 10:25:30:
The engine could be rust stuck, or hydro locked. If a head gasket were leaking, a cylinder can fill with coolant. They will not turn compressing liquid.
Pull the spark plugs and see if there is anything in the holes. If not try it W/O plugs. (ground the coil wire).
In neutral, it should turn clutch or not. JimN
