Posted by JMS1234 on June 04, 2009 at 10:25:30 from (76.117.90.186):
Hi-
I have a Farmall 656 Gas that sat over the winter and now will not start. When the attempting to start I hear the starter motor make a banging sound like it's bumping hard into a stopped gear. The battery is fully charged but it does not turn the engine over... just bangs then makes an unfortunate buzzing sound.
My suspicion is that the clutch is not working and the tractor is stuck in a higher gear.
When I follow the clutch linkage back it does not appear to transmit the pedal movements back to the clutch compartment. And right at the connection to the clutch casing there is a rubber seal that has fallen apart and come off. Any ideas? Should I take the clutch apart or is it unrelated? Perhaps it is time to have it towed to the local tractor repair shop?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
