Re: Farmall 656 doesn't start- could it be a stuck clutch?
Posted by mkirsch on June 04, 2009 at 11:50:07 from (64.80.108.56):
In Reply to: Farmall 656 doesn't start- could it be a stuck clutch? posted by JMS1234 on June 04, 2009 at 10:25:30:
A bad battery cable or other connection will cause the starter to click/bang, but not turn the engine over.
Put the tractor in Neutral, and it won't matter if the clutch is working or not. You don't need the clutch to shift while the tractor is not running.
