Re: Rebuilding 1946 Farmall H transmission
Posted by Theman on June 04, 2009 at 16:09:51 from (63.107.135.35):
In Reply to: Rebuilding 1946 Farmall H transmission posted by Elmer Schields on June 02, 2009 at 14:43:38:
Yes, the pto shaft has a pilot that runs inside a bushing in the back of the bottom countershaft. You can either remove the whole unit (5 bolts) which is easiest, or the seal/bearing retainer (2 bolts) and pull the shaft and engagement collar tube back away from the countershaft. The front and rear bearings of the countershaft should be removed too before trying to remove the shaft. The rear bearing has the mean snap ring that must be removed to slide the bearing off the shaft and out the back of the bulkhead that separates the transmission from the differential areas. It is tight with the gears on the countershaft but it will lift out. That is the way it went in at the factory.
