Rebuilding 1946 Farmall H transmission
Posted by Elmer Schields on June 02, 2009 at 14:43:38 from (4.244.57.144):
Trying to rebuild 1946 Farmall H transmission. Found 4th gear tips ground off. I've taken the top set of gears out. I can move the shaft back and forth. How do I get the shaft out and/or how do I get the bottom gears out. Do I have to take a brass punch and drive them out or do I have to pull the PTO shaft out of the tractor to get to those bottom gears?
