My field lug only connects to one end of the field. The other end of the fields connect only to the brush. My armature lug is connected directly to the brush and it terminates there with no other connections. The ground brush just connects to the case. The generator does not seemed burned, damaged worn or having slung solder. The field is not shorted or open and the brushes are brand new within tight hold down springs. My commutator has deep grooves between the bars. I will check that none of the bars short to the shaft. I am in Virginia but I am willing to ship the generator to have it checked with a growler. Thanks again,
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
