Re: Super A Generator still not generating.
Posted by John T on June 06, 2009 at 04:34:02 from (66.244.97.31):
In Reply to: Re: Super A Generator still not generating. posted by Fred Miller on June 05, 2009 at 19:51:38:
Sounds good, the other (NOT to FLD Post) Field winding end gets EITHER to the ARM terminal orrrrrrrrr to the Armature (non grounded) brush, same place electrically. Still it has to spin/motor if voltage is applied to its ARM post and case/frame and if it wont spin/motor I wouldnt expect it to charge either. If you dead ground the FLD post to case frame and apply voltage to arm post to case/frame ground Id expect it to spin (armature n brushes okay) and then speed up some if the FLD ground is removed (Fields are okay), if its does BOTH of those Id expect it to charge.
Let us know John T
