Posted by Allan In NE on June 08, 2009 at 07:34:39 from (148.78.100.118):
In Reply to: 1066 slow hydralics posted by Ridge farmer on June 08, 2009 at 07:20:36:
The pump for the remotes and the hitch is back down under the left brake and it uses the same filter as the front pump.
You can change that pump in 5 minutes, however the hard part is draining all that derned oil out of the rearend. Have 4 5-gallon open buckets at the ready. :>)
Pull the outer row of bolts to remove pump/plate assembly, Check the o-ring. If it is good, replace the pump.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
