Re: 1066 slow hydralics
Posted by MN Scott on June 08, 2009 at 08:38:33 from (206.9.216.93):
In Reply to: Re: 1066 slow hydralics posted by Allan In NE on June 08, 2009 at 07:34:39:
Allan, an easy way to get most of the oil out is plug a hose in one of the outlets and put the other end in a barrel. Start the tractor and pull back the lever. It will pump all but a few gallons out. Then just stick a barrel pump in the barrel and pump the oil back in. BTW to prevent tweaking that drive in seal in the filter frame you almost have to pull the filter cover and push the tube in from that way.
