Re: super c has no spark from coil
Posted by Bob on June 08, 2009 at 16:41:04 from (69.178.228.68):
In Reply to: Re: super c has no spark from coil posted by barney johnson on June 08, 2009 at 14:45:44:
The light is always "OFF", even while cranking?
If the points are opening and closing as they should the light should be flashing.
Yet, when you manually open the points you get a spark?
If everything you have posted is a correct observation, the point must be gapped so as NOT to open (and close) during cranking???
