Re: super c has no spark from coil
Posted by barney johnson on June 08, 2009 at 14:45:44 from (74.32.166.224):
In Reply to: Re: super c has no spark from coil posted by Bob on June 08, 2009 at 14:31:38:
I put a 12 volt test light from the terminal on the outside of the distributer to a good ground. the light was always off. When I open the points with a screwdriver I do get a spark there. thanks
