Re: H block cracked in dry sleeve bore
Posted by Janicholson on June 08, 2009 at 19:39:45 from (66.173.50.91):
In Reply to: H block cracked in dry sleeve bore posted by Will P on June 08, 2009 at 14:12:01:
It is not common, but happens from either freezing, or heat (possibly the heat you used to remove them) If originally cracked, they would be tough to get out from rust between the sleeve, and the block bore. Tractor Vet is correct on the repair sleeve, but these engine blocks should be pretty common. all the way from H, SH, 300, and 350 used the same basic block. (displacement went up each step, but parts bolt on the block) I would get a good starter block and go from there. JimN
