You can use the nuts used on aircraft. They have a single or two rivets that hold them in place. Aircraft mainly use aluminum though which is easier drilling. Basically have your bolt hole and then drill rivet holes and use small pop rivets to attach the nut. Probably get some at your local airport aircraft maintenance shop or by bulk at Spruce Aircraft supply. Google Spruce and other aircraft nut places to see what they have. Then when you go flying your tractor around at 500 mph you know the hood won't blow off.
I suppose another thing you can do is give each nut a couple tacks with the wire welder while they are properly positioned.
For plain ol assortment of screws, Ace Hardware seems to have the most. Good luck
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
