Sheet metal questions
Posted by jray on June 08, 2009 at 16:13:05 from (98.115.189.116):
I'm just getting started with some restoration on my 350 and I have came on several issues. 1. The metal script(Farmall,350) on the sides of the hood are held on with a little round barrel clip that is stuck into the sheet metal. Where can I get them? 2. The sheet metal (hood,Noise)are held on with screws which pass throught the first sheet and screw into a nut which is captured on the back side of the second sheet. I have several screw where the nut is turning and you can not get a wrench on them to hold them. Any suggestions on how to get this apart with out destroying the nut capturing device? I have been spraying it with WD40. After I get it out, what have your guys been doing to fix the issue?
3. Where can I get new sheet metal screws?
4. The grease verk that goes to the water pump will not take grease. Any suggestions?
5. This tractor was my dads and I can remember that dad did not get very good life out the brake pads. Are their goodbetterbest pads out their to be had? OR do you think something else is worn? I have not open this up yet.
Thanks in advance
Jerry Ray
