I'll try to answer what I can in the order you asked.
1 - Shrug (sorry).
2 - Even if you can get hold of those nuts, you may not be able to get the screws out without messing up the slots in the screw heads. I don't remember how I removed mine, but my first guess would be PB Blaster for the threads and small vise grips for the nuts. Depending on how much time and patience you have, you may find it better to just sacrifice and replace the screws and nuts. At that point, anything goes -- vise grips or even a small pipe wrench on the screw heads, etc.
Fastenal (www.fastenal.com) calls those special nuts with the clips "cage nuts."
I use candle wax or a small amount of anti-seize compound when reinstalling the screws to avoid facing the same situation again later. (For my instrument panel screws, I use stainless steel -- but since you used the word "restoration," you may think that's blasphemy). ;-)
3 - As the other gents said, just about anywhere.
4 - On frozen grease zerks, I give the ball (or the place where the ball should be) a couple of moderate taps with a center punch. If that doesn't work, then a little heat from the propane torch and a couple more taps. If still no luck, then I replace the zerk. Some screw in, some press in. I don't have a manual handy, so I'm not sure which type yours is.
5 - (I'm assuming your brakes are identical or similar to those on a 350 Utility.)
It's important to keep the brakes as clean and dry as possible. Make sure the stationary braking surfaces (all four of the surfaces that the brake disks rub against, eight if you count both left and right brakes) are as clean as you can get them; use lacquer thinner, brake parts cleaner, etc. Make sure no lubricant is leaking along the shaft from the differential (if it is, replace the seal). Also, make sure no hydraulic fluid is leaking on top of the brake cover to seep down inside. Finally, make sure the drain hole on the bottom of the brake cover is unplugged.
I use a little non-hardening gasket goop on the seam between the TOP HALF ONLY of the brake cover and the differential housing. This seems to do a pretty good job of keeping out rain and hydraulic fluid.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
