Re: coolant getting into oil pan on my Farmall c
Posted by 504-2 on June 09, 2009 at 19:42:15 from (216.145.144.254):
In Reply to: coolant getting into oil pan on my Farmall c posted by JDinMi on June 09, 2009 at 18:51:27:
The very first thing to do is drain the anti freeze and fill with water. (anti freeze will eat the bearings fast)If I needed the tractor I would add a can of ginger(kitchen cabinet)to the water and that my be enough to seal it or at least get you buy till you have time to fix it. One other thing to know is anti freeze will find a leak that water won t.
