Re: 756 Hydraulic Update
Posted by LBS MJS on June 09, 2009 at 21:34:52 from (67.55.148.10):
In Reply to: 756 Hydraulic Update posted by MN Scott on June 09, 2009 at 19:50:31:
U can get the bolt out with the IPTO removed.By removing the maim pump it will be easier to get the tube thru the o-ring.No need to remove the top cover.I have done 3 this way.Good luck.
