Re: coolant getting into oil pan on my Farmall c
Posted by El Toro on June 10, 2009 at 04:02:24 from (205.188.116.73):
In Reply to: coolant getting into oil pan on my Farmall c posted by JDinMi on June 09, 2009 at 18:51:27:
I would do as Jim suggested to make sure those seals (donuts) at the bottom of the sleeves aren't leaking. Did you clean that block area thoroughly where the seals are when you installed new sleeves? A lot of crud will buildup in that area over the years of use. Hal
