Re: 300 won't run past idle
Posted by El Toro on June 12, 2009 at 03:56:59 from (64.12.116.73):
In Reply to: 300 won't run past idle posted by Ksfarmmer on June 11, 2009 at 19:38:29:
Charge the battery and reinstall the old coil to see if that fixes the problem. If it doesn't check your fuel system for blockage. When it quits running check for fire to your plugs before it has a chance to cool. If you still have fire
its not the battery or coil. If there's no fire replace the condenser. Hal
