300 won't run past idle
Posted by Ksfarmmer on June 11, 2009 at 19:38:29 from (68.103.49.56):
My 300 Farmall starts great, runs fine at idle but when I try to accelerate it sputters and dies. I suspect it is because the battery is low on charge. I haven't run it at all over the winter and I can see the ammeter peg to the right when I increase the throttle, at least until it dies. Took the battery out and it is charging about 10 amps. Any other suggestions or do you think this will solve the problem? The only other thing that has changed is I installed a new coil, before I put it up for the winter.
