Re: 300 won't run past idle
Posted by Janicholson on June 12, 2009 at 08:49:01 from (199.17.6.22):
In Reply to: Re: 300 won't run past idle posted by Tom 43 on June 12, 2009 at 07:52:58:
Well, with respect, The spark plasma has a tougher time getting through the (to avoid issues with an actual unknown) far lesser molecules in the Idle combustion chamber, than the high pressure fuel and air in the open carb situation. I have been looking at Sun and Allen ignition scopes since 1960. Idle has highest spark voltage demand, wide open, maximum HP at rated speed and has least. Jim
