Re: 300 won't run past idle
Posted by MHMalcolm on June 12, 2009 at 16:25:01 from (66.66.148.252):
In Reply to: Re: 300 won't run past idle posted by MHMalcolm on June 12, 2009 at 16:19:43:
Forgot also to add to check the coil polarity. On a positive ground system, the wire from the distributor should go to the positive terminal, and to the negative terminal on a negative ground system. Polarity makes all the difference when it comes to spark strength.
