Re: 300 won't run past idle
Posted by MHMalcolm on June 12, 2009 at 16:19:43 from (66.66.148.252):
In Reply to: 300 won't run past idle posted by Ksfarmmer on June 11, 2009 at 19:38:29:
Make sure the voltage of new coil you installed matches the voltage of your tractor's system, if you haven't already. The spark from a 12 volt coil will be pretty weak on 6 volts. The engine might start, but will quit when a fog of gas hits the plug when you open the throttle. If your charging system is working, which it sounds like it is, that alone is enough to keep the engine running OK.
