Posted by TomA on June 13, 2009 at 20:58:58 from (64.118.116.51):
I bought this 350 a couple of years ago. I got it pretty cheap because it needed fixing. I am a Cat guy, never owned a wheel tractor before. It was supposed to run but the wheels were locked up. The gas tank was half full of water but the previous owner had run it on a gallon can. I have been working on it in fits and starts over the last 2 years. I find it pretty hard to work on. As I suspected the brakes were locked up. I took them apart and sure enough. Then I found out the steering box was messed up. I had to do some serious dismantaling to get to it. I found a tooth broken of the gear in there. I fixed it by building up with 7018 rod and grinding. I am putting it back together and I think it might work. I can't get much power assist out of it. I am thinking the screen may be plugged. There is a blown hose on the 2 point so I cant use that to test the hydraulics. When I work the valve oil leaks out but it doesn't really squirt out under pressure. I ran a hose from the test port on the high pressure line back to the tank and get mostly foam and milky oil. I could see it had water in it way back and drained it and filled it with new oil and it turned milky right away so I guess it still has water in it. I recall reading a while back that the filter screen is in the tank in the case under the seat. The seat has been collecting nuts and bolts and bits and pieces for a while. I finally got the seat off today and it looks like quite a job to pull the cover off the tank. It looks like the valve bank has to come off with it, I am not sure how many hard lines I will have to disconnect. Am I on the right track here? I hate to start another job that is going to take a year to get done.
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one
... [Read Article]
Latest Ad:
[More Ads]
