Re: 464 transmission problem
Posted by charliet on June 14, 2009 at 08:32:46 from (65.254.172.14):
In Reply to: Re: 464 transmission problem posted by Janicholson on June 14, 2009 at 05:24:05:
"If you have it at high RPM and begin letting out the clutch does the noise begin as soon as the clutch begins to move the tractor? And continue until the tractor and engine are matched in speed (clutch fully locked up driving the trans)?"
Yes, exactly!!! Noise is only there when clutch is "going from in to out" (ie, like when engaging the clutch to move the tractor"). After tractor is moving, the noise "goes away". If I start out in 1st gear and shift through to higher gears after tractor is moving, the noise is much less, almost not there.
It is a "puck" type clutch and I am almost sure it's ceramic. I tried to match the original clutch. Wanted to keep the tractor as "OEM" as possible. Multiple drivers - didn't want drastic changes.
