Re: 464 transmission problem
Posted by Janicholson on June 14, 2009 at 05:24:05 from (66.173.50.28):
In Reply to: 464 transmission problem posted by charliet on June 14, 2009 at 04:42:20:
I would suggest it is the clutch. If you have it at high RPM and begin letting out the clutch does the noise begin as soon as the clutch begins to move the tractor? And continue until the tractor and engine are matched in speed (clutch fully locked up driving the trans)?
If yes, it may be the clutch. Chatter, including both noise and vibration that stops when the clutch is in, or the clutch is driving completely is usually the clutch disk sticking and slipping on the flywheel and pressure plate. It can be from an oil leak gumming up the surfaces, it can be from a ceramic "puck" type clutch, and it can be from mediocre components beginning to fail.
Let us know the noise symptoms a little bit more clearly. JimN
