Re: oil for Farmall B
Posted by Janicholson on June 14, 2009 at 11:46:38 from (66.173.50.90):
In Reply to: oil for Farmall B posted by Rossputin on June 14, 2009 at 10:47:42:
automotive 10-40 or 15-40 diesel grade will both be fine oils. The modern oils are so much better than the oil of its birth, that there is no issue. Multi Wt. oils are good.
The coolant should be either the yellow, or the universal style antifreeze 50/50 with clean (distilled is best) water.
Do not use the gas additives at all. Just not needed. There is no record of these engines having issues with unleaded or 10% Ethanol.
B tractors have about 4 inches from the right seat support to the fender on the right. The BN has the seat bracket on the fender directly.
JimN
