Posted by Rossputin on June 14, 2009 at 10:47:42 from (72.42.107.108):
Hello all,
Thanks in large part to your encouragement, I just took delivery of my 1941 Farmall B.
There are larger versions of the pictures at: http://www.rossputin.com/tractor1.htm (the same link as at the end of this note)
I have a few quick questions for the experts:
1) How can I tell if it's a BN? On the serial number tag, the model says "B", but the serial number seems to start with "FABN" although the "N" is questionable as it's slightly fainter and has a mark across it that makes it look a little like an "X". I'll try to post a picture soon.
2) What oil should I use? Where I live it usually doesn't get above high 70's in the summer, it's typically 40's-60's in spring and fall, and winter can have 0 degree days though teens to twenties is more typical. I do plan to use it on occasion to plow snow in winter. Is there an oil I can put in that will work for all seasons, or should I expect to have to change oil between summer and winter? Also, should I follow the guidance to use "non-detergent" oil even though the tractor has an oil filter?
3) Any advice on coolant?
4) Should I add "lead substitute" to the unleaded gasoline?
I'm sure there will be more later, but thanks in advance for your thoughts and your encouragement!
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
