Re: 856 vs 400 fuel consumption
Posted by Janicholson on June 15, 2009 at 07:48:36 from (66.173.50.88):
In Reply to: Re: 856 vs 400 fuel consumption posted by Hugh MacKay on June 15, 2009 at 07:00:36:
Nutshell from Jim (hypothesis) A diesel will have a substantially larger flywheel and rotating (moving inertial mass) than a gasser. It will also have a more direct reaction to governor response and speed control. A gasser will drop 5 to 10% in engine speed to get to its sweet spot in the torque curve, whereas a diesel may not be pulled down 2%. The above makes for less speed drop, more continuity in RPM, and less direct piston pulse related change in the power delivery.
An impact wrench will twist off bolts that a torque wrench will not. (assumes the averaged torque is equal) One is steady, the other is pulsed higher and lower than the average. JimN
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
