Re: Farmall M seal behind brake
Posted by John M on June 15, 2009 at 15:04:26 from (206.74.31.199):
In Reply to: Farmall M seal behind brake posted by MJF on June 15, 2009 at 08:17:32:
Remember unless you can "rig" you up a way to pull the old seal out, you have to remove the diffs. to get the seal out. I change a few by drilling a small hole on each side of the seal, and driving a screw in tothe seal casing and pulling it out little at a time with my big pliers.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
