Re: Farmall M seal behind brake
Posted by Chris NW Ind on June 16, 2009 at 06:11:47 from (64.136.26.235):
In Reply to: Re: Farmall M seal behind brake posted by John M on June 15, 2009 at 15:04:26:
Same here. I drilled 2 holes 180 degrees apart, screwed in 2 lag bolts, and used a small prybar to walk the seal out. Don't even try to pull the differential casting unless you have the bull gears off.
Chris B.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
