Posted by Tom Fleming on June 16, 2009 at 17:58:52 from (67.20.245.118):
I had to replace the front axel on my Farmall A. Got the tie-rods off with no issue. Cleaned them up, etched, primed, and painted them. Put them back together, and went to put them on the tractor after replacing the front axel.........and the one tie rod will NOT go on, as it appears the ball-joint insert is too thick. This really has me puzzled, as both rods were on the tractor.
so, either I am doing something realy stupid (very high possibility), or something is wrong. I will share that the ball-joint inserts with the flat ends are not the same thickness. I tried them on both sides with the same results. Thin one works like a champ, thick one will not provide enough clearance to fit over the ball. :roll:
Any thoughts, suggestions, or a kick in the pants to indicate what I am doing wrong?
Anyone know a source for replacement inserts, or what the thickness measurement is for the correct size?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
