Re: Farmall A tie-rod question
Posted by Tom Fleming on June 20, 2009 at 14:34:38 from (67.20.245.118):
In Reply to: Farmall A tie-rod question posted by Tom Fleming on June 16, 2009 at 17:58:52:
My mystery is solved, and I thought I would post for future reference, so no one else has to go through my trouble.
There are 2 ball-joint inserts for the center steering arm. One is flat on one side, and rather thick 1/2" (thicker than the ones for the tie-rod ends). It goes at the bottom (end) of the blind side of the steering arm. Next, goes the ball-joint end of the tie rod. Next goes the double sided insert. Then install the opposite tie-rod. Lastly, install the set-screw.
The inserts for the tie-rod ends are approx 5/16" thick, and are flat on 1 side. One per side, with the flat end (of course) going into the far end of the tie-rod end.
I found that I had 1 of the tie-rod end inserts "missing" as someone in the past installed 2 7/16" washers as the ball joint inserts. I thought they were just spacers for wear. Turns out, they were intended to be the insert.
Went to the local tractor grave yard, Charlie Burgh's, and retrieved another insert.
Works like a champ.
