Re: Super C: Two Questions
Posted by mkirsch on June 17, 2009 at 05:27:19 from (64.80.108.56):
In Reply to: Super C: Two Questions posted by Smith1000 on June 16, 2009 at 18:27:44:
The governor should not INCREASE the engine speed. It should maintain the same engine speed, unless the combination of load, gear, and field conditions exceed the power output of the engine. Then it will lug down, and you will have to shift.
Your problem could be simple: The combination of running the mower and going up the hill could require more power than the engine can produce.
A non-working governor would show up every time you let out the clutch to move the tractor.
Did you turn the screw in the bottom of the governor? It could be that you turned it in too much to stop the surging.
