Beginnings of a 400 hydro-creeper
Posted by Wardner on June 18, 2009 at 15:59:59 from (4.154.244.134):
This is the driveshaft. It is made from an over-running PTO coupler that is used on non-IPTO tractors. The guts were discarded and I fitted the key into the slots. This guarantees perfect concentricity. I turned the outside so it would tightly fit the 400 brake cover. This helped in fitting the other parts. I'll cut that off later.
third party image
Here it is jammed into brake cover. The turning that you see is for the throwout bearing.
third party image
The throwout bearing is from a 400 TA clutch.
third party image
The spring disengages the driveshaft from the bull pinion gearshaft.third party image
Stay turned. I'll have more pictures tomorrow. This hydro-creeper will be air shifted and variable speed. It will have its own hydraulic power. Did you want to see the compressor? OK.
third party image
